Products description
The easy to process and flexible thermal pads featuring outstanding thermal conductivity.
Specifications minus pad 8:
Thermal conductivity: 8.0 W/mK
Temperature range: -100 °C to +200 °C
The Minus Pads 8 are available in three different sizes (30x30 mm, 120x20 mm and 100x100 mm) and five different thicknesses (0.5 mm, 1 mm, 1.5 mm, 2 mm, 3 mm).
This Product was added to our catalogue on 15/03/2018.
Manufacturer Information
Contact Manufacturer
Thermal Grizzly Holding GmbH Gewerbestr. 39
16540 Hohen Neuendorf
Germany
support@thermal-grizzly.com
Customers who bought this product also bought the following products:
A product slider follows - navigate to the individual items using the Tab key.
Thermal Grizzly Minus Pad 8 - 120 × 20 × 2,0 mm
Thermal Grizzly Minus Pad 8 - 120 × 20 × 3,0 mm
OCTO fan controller for PWM fans
Thermal Grizzly Duronaut thermal compound - 2 grams
Double Protect Ultra 1l
Decoupling set for pump installations, extra-soft yellow rubber buffers
Last viewed:
Thermal Grizzly Minus Pad 8 - 120 × 20 × 1,0 mm, 2 pieces
