Products description
The Conductonaut liquid metal thermal compound is designed for applications that require very high efficiency. Conductonaut is recommended for experienced users who are looking for a top performance product with best heat dissipation where temperature ranges are above 8 °C.
- Ultra high thermal conductivity
- Increased indium content
- Easy application with synthetic needle
Technical details:
Thermal conductivity: 73 W/mk
Viscosity: 0.0021 Pas
Specific weight: 6.24 g/cm3
Temperature: 10 °C to 140 °C
Important information:
The Conductonaut liquid metal thermal compound must not be used in contact to aluminum surfaces and must not get in contact with electrical contacts of hardware components! This prohibits use of aluminum heat sinks. Use heat sinks with copper, nickel or silver surfaces instead. Users are advised to be extremely cautious, the liquid metal compound must not get in contact with the multitude of electronic components around and under the heat spreader or die of the CPU, this applies to all CPU types such as Intel Haswell, Devil's Canyon, Broadwell and Skylake CPUs as well as AMD CPUs!
Storage:
Store in original packaging in dry rooms, temperature approx. 20 °C.
Warnings and safety information:
Avoid eye and skin contact! Keep away from children!
Contact a doctor immediately if swallowed or after eye contact!
Conductonaut is based on liquid metal and must not be used with coolers made out of aluminium! Contact with aluminium will result in a permanent damage of the cooling unit! Coolers with Direct-Heatpipe-Touch may only be used if the base is made out of copper!
Technical details:
Storage:
This Product was added to our catalogue on 15/07/2016.
Manufacturer Information
Contact Manufacturer
Thermal Grizzly Holding GmbH Gewerbestr. 39
16540 Hohen Neuendorf
Germany
support@thermal-grizzly.com
Customers who bought this product also bought the following products:
A product slider follows - navigate to the individual items using the Tab key.
Filter with stainless steel mesh, ball valves and mounting plate, G1/4
cuplex kryos NEXT VARIO 1851/1700, nickel/nickel
Temperature sensor G1/4
Double Protect Ultra 5l canister
Barrow 16 mm hard tube fitting G1/4, extended edition, black
Barrow bending templates 45°/90°/180° for 16 mm hard tubes
Last viewed:
Thermal Grizzly Conductonaut liquid metal thermal compound - 5 gram
