Products description
Kryonaut thermal grease was created especially for the extremely demanding applications and the highest expectations of the overclocking community. Kryonaut is also highly recommended as a top product for critical cooling systems in the industrial environment.
- designed for Overclocking
- excellent thermal conductivity
- no curing
- long-term durability
- no electrical conductivity
- applicable with aluminum
Technical details:
Thermal conductivity: 12.5 W/mk
Viscosity: 130-170 Pas
Specific weight: 3.7 g/cm3
Temperature: -200 °C to +350 °C
Warnings and safety information:
Avoid eye and skin contact! Keep away from children!
Contact a doctor immediately if swallowed or after eye contact!
- no curing
Technical details:
This Product was added to our catalogue on 15/07/2016.
Manufacturer Information
Contact Manufacturer
Thermal Grizzly Holding GmbH Gewerbestr. 39
16540 Hohen Neuendorf
Germany
support@thermal-grizzly.com
Customers who bought this product also bought the following products:
A product slider follows - navigate to the individual items using the Tab key.
Pressure spring stainless steel, length 12 mm, outer diameter 7.6 mm
Retrofit kit socket 1851/1700 for cuplex kryos NEXT acrylic glass version
aquabus Y-connector 4 pins
Gasket 13.3 x 1.78 mm for inline temperature sensor, calitemp
aquabus cable 4 pins for VISION, OCTO, QUADRO, D5 NEXT
Calitemp digital temperature sensor internal/external thread G1/4 for aquaero 5/6
Last viewed:
Thermal Grizzly Kryonaut thermal compound - 11.1 grams / 3 ml
