Products description
Combined GPU/RAM/VRM-cooler for graphics cards of the type ATi HD 3870 according to reference design.
This cooler combines the features of a graphics chip cooler and RAM-coolers in an elegant and very flat watercooler. Thereby the slot next to the PCI-Express-slot remains useable.
Additionally the voltage regulators are also cooled effectively.
The cooler is manufactured out of copper with a stainless steel cover, the connection terminal is made of Plexiglas. We recommend straight plug&cool connectors as fittings.
Scope of delivery:
cooler without connectors (screw threads G 1/4)
Please note:
Graphic card and fittings are not included in delivery, please order separately. Threads are G 1/4.
The cooler is not suitable for graphics cards from Powercolor and Sapphire.
Crossfire compatible when equipped with bent plug&cool fittings (Art. 90006).
Reviews:
Test at PCMasters.de (German)
Scope of delivery:
Please note:
Reviews:
This Product was added to our catalogue on 05/12/2008.
Manufacturer Information
Contact Manufacturer
Aqua Computer GmbH & Co. KG Gelliehäuser Str. 1
37130 Gleichen
Germany
info@aqua-computer.de
Anschlüsse
A product slider follows - navigate to the individual items using the Tab key.
Coupling 10/8 mm G 1/4 with O-gasket
Coupling 10/8 mm G 1/4 m. O-gasket elbow, pivotable
Coupling 8/6 mm G 1/4 with O-gasket
Coupling 8/6 mm G 1/4 w. O-gasket elbow, pivotable
Coupling 11/8 mm G 1/4, straight
Coupling 11/8 mm G 1/4 elbow, pivotable
Coupling 13/10 mm G 1/4 with O-gasket
Coupling 13/10 mm G 1/4 m. O-gasket elbow, pivotable
Customers who bought this product also bought the following products:
Coupling 11/8 mm G 1/8 elbow, pivotable
Ball valve internal thread G 1/4
Temperature sensor inline G1/4
Temperature sensor internal/external thread G1/4
Plug for power output connector (aquaero 5 and 6) or relay connector (aquaero 4), 2 contacts
Elbow fitting plug&cool G 1/8, pivotable
Last viewed:
aquagratiX for HD 3870 (RV670) G1/4
cuplex kryos NEXT with VISION 2011/2011-3/2066, copper/copper
