Products description
Combined GPU/RAM/VRM-cooler for graphics cards of the type nvidia GeForce GTX 680 with 2048 MB RAM according to reference design.
This cooler combines the features of a graphics chip cooler and RAM-coolers in an elegant and very flat watercooler. Additionally the voltage regulators are also cooled effectively.
The kryographics for GTX 680 water block offers outstanding cooling performance and a low flow resistance. All mounting threads are equipped with spacers for easy installation and to prevent twisting the graphics card. The areas contacting the GPU and RAM modules are polished for excellent heat transfer. For the voltage regulators, a thermal pad with high thermal conductivity is included.
The kryoconnect water block series features a delrin connection terminal that has a significantly reduced flow resistance compared to the previous aquagraFX series. The terminal is fastened to the water block by three screws and has G1/4 inlet and outlet ports on each side for flexible installation. Two sealing screws are supplied to seal the unused connection threads. The terminal can be replaced with kryoconnect kits for SLI configurations (art. no. 23551, 23552 or 23553, not included in delivery).
Materials:
Base part: Copper, nickel plated
Top cover: Stainless steel
Terminal: Delrin
Scope of delivery:
cooler without connectors (screw threads G 1/4)
mounting material incl. thermally conductive pad
two sealing plugs for unused connection threads
Torx screwdriver (for removal of the air cooling unit)
Please note:
Graphic card and fittings are not included in delivery, please order separately. Threads are G 1/4.
Installation-Video:
Materials:
Terminal: Delrin
Scope of delivery:
Please note:
Installation-Video:
This Product was added to our catalogue on 28/05/2013.
Manufacturer Information
Contact Manufacturer
Aqua Computer GmbH & Co. KG Gelliehäuser Str. 1
37130 Gleichen
Germany
info@aqua-computer.de
Anschlüsse
A product slider follows - navigate to the individual items using the Tab key.
Coupling 10/8 mm G 1/4 with O-gasket
Coupling 10/8 mm G 1/4 m. O-gasket elbow, pivotable
Coupling 8/6 mm G 1/4 with O-gasket
Coupling 8/6 mm G 1/4 w. O-gasket elbow, pivotable
Coupling 11/8 mm G 1/4, straight
Coupling 11/8 mm G 1/4 elbow, pivotable
Coupling 13/10 mm G 1/4 with O-gasket
Coupling 13/10 mm G 1/4 m. O-gasket elbow, pivotable
Straight plug&cool fitting G 1/4
Elbow fitting plug&cool G 1/4, pivotable
Zubehör
kryoconnect kit for kryographics, width 4 slots for 2 graphics cards
kryoconnect kit for kryographics, width 5 slots for 2 or 3 graphics cards
kryoconnect kit for kryographics, width 7 slots for max. 7 graphics cards
Customers who bought this product also bought the following products:
Adapter set for 1046 and aquastream, G1/4
Connection cable for flow sensor, length 70 cm for aquaero/aquastream/poweradjust/D5 NEXT
Temperature sensor internal/external thread G1/4
aquastream XT Upgrade Kit to aquastream ULTIMATE
Backplate for aquagrafx GTX 680
aquaero power connect - 24 pin ATX standby power / ATX break
Last viewed:
kryographics for GTX 680, nickel plated version
