kryographics for GTX 780 Ti black edition
Product no.: 23590
GTIN/EAN: 4260073417655
MPN: 23590
If there is more than one product image, you can use the "Previous" and "Next" buttons to navigate between the images. For a larger view click on the image.
For a larger view click on the image!
49,90 EUR
incl. 19 % VAT excl. shipping costs
Products description
Combined GPU/RAM/VRM-cooler for graphics cards of the type nvidia GTX 780 Ti with 3072 MB RAM according to reference design.
This cooler combines the features of a graphics chip cooler and RAM-coolers in an elegant and very flat watercooler. Additionally the voltage regulators are also cooled effectively.
The kryographics for GTX 780 Ti water block offers outstanding cooling performance and a low flow resistance. All mounting threads are equipped with spacers for easy installation and to prevent twisting the graphics card. The areas contacting the GPU and RAM modules are polished for excellent heat transfer. For the voltage regulators, a thermal pad with high thermal conductivity is included.
The kryoconnect water block series features a delrin connection terminal that has a significantly reduced flow resistance compared to the previous aquagraFX series. The terminal is fastened to the water block by three screws and has G1/4 inlet and outlet ports on each side for flexible installation. Two sealing screws are supplied to seal the unused connection threads. The terminal can be replaced with kryoconnect kits for SLI configurations (art. no. 23551, 23552 or 23553, not included in delivery).
Materials:
Base part: Copper
Top cover: Acrylic glass with stainless steel frame
Terminal: Delrin
Scope of delivery:
cooler without connectors (screw threads G 1/4)
mounting material incl. thermally conductive pad
two sealing plugs for unused connection threads
Please note:
Graphic card and fittings are not included in delivery, please order separately. Threads are G 1/4. Thermally conductive paste is required for installation.
Please note that blocks from a current production run are compatible to the GTX (Black) series as well as the GTX 780 (Ti) series. Other than shown such blocks have the engravig "GK110".
Installation video:
This Product was added to our catalogue on 07/01/2014.
Manufacturer Information
Contact Manufacturer
Aqua Computer GmbH & Co. KG
Gelliehäuser Str. 1
37130 Gleichen
Germany
info@aqua-computer.de
Anschlüsse
A product slider follows - navigate to the individual items using the Tab key.
Coupling 10/8 mm G 1/4 with O-gasket
Coupling 10/8 mm G 1/4 m. O-gasket elbow, pivotable
Coupling 8/6 mm G 1/4 with O-gasket
Coupling 8/6 mm G 1/4 w. O-gasket elbow, pivotable
Coupling 11/8 mm G 1/4, straight
Coupling 11/8 mm G 1/4 elbow, pivotable
Coupling 13/10 mm G 1/4 with O-gasket
Coupling 13/10 mm G 1/4 m. O-gasket elbow, pivotable
Straight plug&cool fitting G 1/4
Elbow fitting plug&cool G 1/4, pivotable
Zubehör
kryoconnect kit for kryographics, width 4 slots for 2 graphics cards
kryoconnect kit for kryographics, width 5 slots for 2 or 3 graphics cards
kryoconnect kit for kryographics, width 7 slots for max. 7 graphics cards
Customers who bought this product also bought the following products:
Tubing PUR natur, plug&cool
Elbow connector plug&cool metal
Double Protect Ultra 1l - red
Decoupling set for pump installations, extra-soft yellow rubber buffers
Last viewed:
Double Protect Ultra 5l canister - blue
Locking cap plug&cool plastic
Settings
Shipping country
Languages
Your account
Categories
