Water block for kryoM.2, nickel plated
Product no.: 53229
GTIN/EAN: 4260073419505
MPN: 53229
If there is more than one product image, you can use the "Previous" and "Next" buttons to navigate between the images. For a larger view click on the image.
For a larger view click on the image!
59,90 EUR
incl. 19 % VAT excl. shipping costs
Products description
Water block for kryoM.2 PCIe adapter board.
The connector terminal of the water block is the same as used for the kryographics blocks. This allows using kryoconnect adapter kits to connect several blocks directly with each other.
Material:
Base: Copper, nickel plated
Lid: Stainless steel
Connection terminal: Acetal
Scope of delivery:
Water block, G1/4 connection threads
Mounting material
Compatible with:
kryoM.2 evo (53246, 53304, 53305)
kryoM.2 (53222, 53223, 53224, 53228)
This Product was added to our catalogue on 30/05/2016.
Manufacturer Information
Contact Manufacturer
Aqua Computer GmbH & Co. KG
Gelliehäuser Str. 1
37130 Gleichen
Germany
info@aqua-computer.de
Customers who bought this product also bought the following products:
A product slider follows - navigate to the individual items using the Tab key.
ArctiClean cleansing set
Rubber buffer for aquadrive, M3 internal threads
Hose barb 10 mm G1/8 with O-ring gasket
Rotary elbow adapter G1/4
ATX start plug
ATX start plug
Filter with stainless steel mesh, ball valves and mounting plate, G1/4
Last viewed:
Precision roll forged drill 8.8 mm for tapping hole G1/8
Screw M4 x 6 mm, low head socket cap, hexagon socket, A2
Conversion kit CP4 type 2 for twinplex
cuplex kryos NEXT with VISION AM5/AM4 9000/8000/7000/5000/3000, PVD/nickel
Screw M5 x 14 mm, low head socket cap, hexagon socket, A2
Settings
Shipping country
Languages
Your account
Categories
