Accessories
Acrylic glass display cover for aquaero 5/6 PRO
aquabus / RPM signal cable 3 pins
aquabus / RPM signal cable 3 pins, 15 cm
aquabus cable 4 pins
aquabus cable 4 pins for VISION, OCTO, QUADRO, D5 NEXT
aquabus cable 4 pins, 15 cm
aquabus Y-connector 4 pins
aquaero power connect - 24 pin ATX standby power / ATX break
Connection cable alarm header of aquastream ULTIMATE to motherboard power switch header
Connection cable alarm header with miniature connector to motherboard power switch header
Connection cable for Laing D5 und DDC pumps for poweradjust 2/3 and aquaero 5/6
Connection cable signal header miniature connector (high flow NEXT, OCTO) to fan header
Connection cable signal header of high flow NEXT to 3 pin miniature connector
Mounting material aquaero 5/6 LT for drive bay
Plug for power output connector (aquaero 5 and 6) or relay connector (aquaero 4), 2 contacts
Plug for relay connector, 3 contacts (aquaero 5 and 6)
Power supply 4-Pin Y-Splitter
RGB illumination module for aquaero 5 and 6
