Products description
Connection cable for high flow 2 (53292) and high flow LT (53291). Total length including connectors approx. 70 cm.
Scope of delivery: One cable
This Product was added to our catalogue on 12/10/2021.
Manufacturer Information
Contact Manufacturer
Aqua Computer GmbH & Co. KG Gelliehäuser Str. 1
37130 Gleichen
Germany
info@aqua-computer.de
Customers who bought this product also bought the following products:
A product slider follows - navigate to the individual items using the Tab key.
Sealing screw G 1/4 incl. gasket
Aqua Computer D5 pump motor with PWM input and speed signal
Set screw G 1/4, cylindrical
Connection cable alarm header with miniature connector to motherboard power switch header
RGBpx cable, length 200 cm
Barrow acrylic hard tube 16/12 mm, length 500 mm
Last viewed:
Connection cable for high flow 2 and high flow LT, length 70 cm
