Products description
Connection cable for high flow LT (53291). Total length including connectors approx. 70 cm.
Scope of delivery: One cable
This Product was added to our catalogue on 25/09/2024.
Manufacturer Information
Contact Manufacturer
Aqua Computer GmbH & Co. KG Gelliehäuser Str. 1
37130 Gleichen
Germany
info@aqua-computer.de
Customers who bought this product also bought the following products:
A product slider follows - navigate to the individual items using the Tab key.
Double Protect Ultra 5l canister
RGBpx Splitty12 ACTIVE
Sealing screw G 1/4 incl. gasket
internal USB connection cable 100 cm
USB cable A-plug to 5 pin female connector, length 200 cm
aquabus cable 4 pins for VISION, OCTO, QUADRO, D5 NEXT
Last viewed:
Connection cable for high flow LT, length 70 cm
