Products description
VISION module assembly to be used as a replacement part for VISION Glow table top unit (53236).
Notes on the aquasuite software:
When you activate this product you will receive the current version of the aquasuite software including an upgrade service for at least six (6) months. After the expiration of the upgrade service you may use and reinstall the latest version available during the upgrade period without a time limit.
The update service can optionally be extended or renewed at any time for a fee.
Please note that an internet connection is required for the installation and activation of the aquasuite software.
Further information about the update service and the activation of the aquasuite software can be found here.
This Product was added to our catalogue on 28/12/2016.
Manufacturer Information
Contact Manufacturer
Aqua Computer GmbH & Co. KG Gelliehäuser Str. 1
37130 Gleichen
Germany
info@aqua-computer.de
Customers who bought this product also bought the following products:
A product slider follows - navigate to the individual items using the Tab key.
VISION Glow table top unit with IR receiver and ambient temperature sensor
internal USB connection cable 100 cm with miniature connector
Illumination insert G1/8 incl. gasket
Temperature sensor 70 cm
Connection cable for flow sensor, length 70 cm for aquaero/aquastream/poweradjust/D5 NEXT
aquaero power connect - 24 pin ATX standby power / ATX break
Last viewed:
VISION Glow replacement module for table top unit
