VISION replacement module for kryographics connection terminal
Product no.: 53240
GTIN/EAN: 4260473310938
MPN: 53240
If there is more than one product image, you can use the "Previous" and "Next" buttons to navigate between the images. For a larger view click on the image.
For a larger view click on the image!
22,90 EUR
incl. 19 % VAT excl. shipping costs
Products description
VISION module assembly to be used as a replacement part for VISION connection terminal for kryographics (23664, 23666).
Notes on the aquasuite software:
When you activate this product you will receive the current version of the aquasuite software including an upgrade service for at least six (6) months. After the expiration of the upgrade service you may use and reinstall the latest version available during the upgrade period without a time limit.
The update service can optionally be extended or renewed at any time for a fee.
Please note that an internet connection is required for the installation and activation of the aquasuite software.
Further information about the update service and the activation of the aquasuite software can be found here.
This Product was added to our catalogue on 28/12/2016.
Manufacturer Information
Contact Manufacturer
Aqua Computer GmbH & Co. KG
Gelliehäuser Str. 1
37130 Gleichen
Germany
info@aqua-computer.de
Customers who bought this product also bought the following products:
A product slider follows - navigate to the individual items using the Tab key.
Connection cable flow sensor for VISION, OCTO, QUADRO, farbwerk 360
Connection cable alarm header with miniature connector to motherboard power switch header
Connection cable signal header of high flow NEXT to 3 pin miniature connector
Replacement glass tube for ULTITUBE 50 reservoirs
ATX start plug
ATX start plug
internal USB connection cable 100 cm with miniature connector
Last viewed:
Settings
Shipping country
Languages
Your account
Categories
