Products description
Dr. Drop is an ingeniously simple pressure tester for your entire water cooling loop or for single components.
With an included air pump, a test pressure can be applied. A large manometer with a diameter of 63 mm allows for precise pressure readings. A second valve is included to adjust pressure for easy testing over prolonged periods of time and to discharge the pressure after testing.
The pressure tester has a G1/4 inner thread to be equipped with a hose fitting compatible to your preferred hose diameter.
Added bonus for bicyclists: The air pump fits car tire valves (Schrader) as well as French (Sclaverand) tyre valves. A pump holder (hole pattern like bottle holder) is included as well.
Technical details:
Base part material: Delrin, black
Measuring range: 0 - 0.6 bar (approx. 0 - 8.7 PSI)
Connection thread: G1/4
Scope of delivery:
Pressure tester
Air pump
Hose fitting and hose not included in delivery!
Technical details:
Scope of delivery:
Pressure tester
Air pump
This Product was added to our catalogue on 21/06/2019.
Manufacturer Information
Contact Manufacturer
Aqua Computer GmbH & Co. KG Gelliehäuser Str. 1
37130 Gleichen
Germany
info@aqua-computer.de
Anschlüsse
A product slider follows - navigate to the individual items using the Tab key.
Coupling 10/8 mm G 1/4 with O-gasket
Coupling 10/8 mm G 1/4 m. O-gasket elbow, pivotable
Coupling 8/6 mm G 1/4 with O-gasket
Coupling 8/6 mm G 1/4 w. O-gasket elbow, pivotable
Coupling 11/8 mm G 1/4, straight
Coupling 11/8 mm G 1/4 elbow, pivotable
Coupling 13/10 mm G 1/4 with O-gasket
Coupling 13/10 mm G 1/4 m. O-gasket elbow, pivotable
Straight plug&cool fitting G 1/4
Elbow fitting plug&cool G 1/4, pivotable
Customers who bought this product also bought the following products:
Fan extension cable / aquabus extension cable 3 pins, 50cm
Hose cutter for a maximum diameter of 16 mm
Passive heat sink for aquaero 6, black
Fan extension cable / aquabus extension cable 4 pins, 50cm
Hose Aqua Computer 16/10 mm EPDM black
Replacement connection terminal (one circuit) for airplex modularity system
Last viewed:
Dr. Drop PROFESSIONAL pressure tester incl. air pump
