Accessories
D5 fan mount 120 mm
D5 fan mount 140 mm
Sealing plate D5
ULTITOP D5 pump cover for D5 pumps, G1/4
Decoupling set for aquastream ULTIMATE and aquastream XT
ULTITOP DDC pump cover for DDC pumps, G1/4
ULTITOP DUAL D5 pump cover for two D5 pumps, G1/4
ULTITOP D5 MIRROR BLACK pump cover for D5 pumps, G1/4
ULTITOP DDC MIRROR BLACK pump cover for DDC pumps, G1/4
ULTITOP DUAL D5 MIRROR BLACK pump cover for two D5 pumps, G1/4
Adapter set for 1046 and aquastream, G1/4
Decoupling set for pump installations, extra-soft yellow rubber buffers
aquastream XT Upgrade Kit to aquastream ULTIMATE
Upgrade aquastream XT USB Standard to version Ultra
Upgrade aquastream XT USB Advanced to Version Ultra
Upgrade aquastream XT USB Standard to version Advanced
Pump adapter for D5 pumps for aqualis base with fill level sensor, G1/4
Pump adapter for D5 pumps, compatible with aqualis base, G1/4
aquacover dual DDC pump cover for DDC pumps, G1/4
aquacover DDC pump cover for DDC pumps, G1/4
Pumpenhalterung aus Edelstahl zur Befestigung an einem Radiator
Adapter aquastream and Eheim 1046/1048 suction side to G1/4
Adapter aquastream and Eheim 1046/1048 suction side to G1/8
Adapter Eheim 1046 and aquastream pressure side to G1/4
Adapter for Hydor L20/L30 (G1/2) with gasket to G1/4
