Thermally conductive pad for ramplex, thickness 1 mm, 3.5 W/mK
Product no.: 51206
GTIN/EAN: 4260473312178
MPN: 51206
If there is more than one product image, you can use the "Previous" and "Next" buttons to navigate between the images. For a larger view click on the image.
For a larger view click on the image!
2,49 EUR
incl. 19 % VAT excl. shipping costs
Products description
This thermally conductive pad is ideally suited to be used with a ramplex series water block. It is made from soft, silicone based material and is equipped with an adhesive couating on one side of the pad for easy installation.
Dimensions: ca. 120 x 20 x 1 mm
Maximum gap to be filled: 1 mm
Thermal conductivity: 3,5 W/mK
Not electrically conductive
Scope of delivery: One thermally conductive pad
This Product was added to our catalogue on 05/12/2008.
Manufacturer Information
Contact Manufacturer
Aqua Computer GmbH & Co. KG
Gelliehäuser Str. 1
37130 Gleichen
Germany
info@aqua-computer.de
Customers who bought this product also bought the following products:
A product slider follows - navigate to the individual items using the Tab key.
Thermally conductive pad for kryographics and ramplex, thickness 0.5 mm, 3.5 W/mK
Thermal Grizzly Minus Pad 8 - 120 × 20 × 2,0 mm
Aqua Computer D5 pump motor with PWM input and speed signal
Connection cable alarm header with miniature connector to motherboard power switch header
OCTO fan controller for PWM fans
Thermal Grizzly Duronaut thermal compound - 2 grams
Last viewed:
Threaded insets for airplex radical, 4 pieces
Settings
Shipping country
Languages
Your account
Categories
