Products description
Please note: Second quality with slight optical defects such as scratches or defects in the surface plating, no functional defects. Available as long as stock lasts only.
Exceptionally compact top for DDC pumps, manufactured from solid brass, manually polished and with a dark nickel plating. Main focus during development of the ULTITOP DDC were optimum flow characteristics, reducing noise and vibration to a bare minimum.
Both mounting brackets are equipped with silicone decouplers specifically designed for the ULTITOP, effectively preventing remaining vibrations from being transmitted to the PC case. Stainless steel plates with M3 threads inserted into the decouplers ensure convenient installation.
Dimensions:
62 x 62 x 19 mm without bracket/decouplers, without pump
62 x 93 x 44 mm with bracket/decouplers, without pump
Scope of delivery:
Pump adapter
Stainless steel brackets with silicone decouplers
Mounting material
Compatible with:
Laing DDC series pumps and OEM versions identical in construction
Please note:
Pump and fittings are not included in delivery!
Due to the high weight, a hanging mounting with the supplied silicone decouplers is not possible. An upright mounting is recommended.
Dimensions:
Scope of delivery:
Pump adapter
Mounting material
Compatible with:
Please note:
This Product was added to our catalogue on 24/04/2025.
Manufacturer Information
Contact Manufacturer
Aqua Computer GmbH & Co. KG Gelliehäuser Str. 1
37130 Gleichen
Germany
info@aqua-computer.de
Zubehör
A product slider follows - navigate to the individual items using the Tab key.
Laing DDC-Pumpe 12V DDC-1T
Laing DDC-Pumpe 12V DDC-1T Plus
Laing DDC-Pumpe 12V DDC-1T Plus PWM
Customers who bought this product also bought the following products:
Temperature sensor internal/external thread G1/4
Double Protect Ultra 1l
Decoupling set for pump installations, extra-soft yellow rubber buffers
Front plate for aquaero 5 und 6 XT (53125, 53146 and 53206) aluminum black
farbwerk 360
ULTITOP D5 pump cover for D5 pumps, G1/4
Last viewed:
ULTITOP DDC MIRROR BLACK pump cover for DDC pumps, G1/4, second quality
