Products description
Combined GPU/RAM/VRM-cooler for graphics cards of the type nvidia GTX 980 with 4 GB RAM according to reference design.
This cooler combines the features of a graphics chip cooler and RAM-coolers in an elegant and very flat watercooler. Additionally the voltage regulators are also cooled effectively.
The kryographics for GTX 980 water block offers outstanding cooling performance and a low flow resistance. All mounting threads are equipped with spacers for easy installation and to prevent twisting the graphics card. The areas contacting the GPU and RAM modules are polished for excellent heat transfer. For the voltage regulators, a thermal pad with high thermal conductivity is included.
To allow an even contact pressure in the area of the voltage regulators the block comes with a small stainless steel backplate.
The kryoconnect water block series features a delrin connection terminal that has a significantly reduced flow resistance compared to the previous aquagraFX series. The terminal is fastened to the water block by three screws and has G1/4 inlet and outlet ports on each side for flexible installation. Two sealing screws are supplied to seal the unused connection threads. The terminal can be replaced with kryoconnect kits for SLI configurations (art. no. 23551, 23552 or 23553, not included in delivery).
Materials:
Base part: Copper, nickel plated
Top cover: Acrylic glass with stainless steel frame
Terminal: Delrin
Scope of delivery:
cooler without connectors (screw threads G 1/4)
mounting material incl. thermally conductive pad
two sealing plugs for unused connection threads
Please note:
Graphic card and fittings are not included in delivery, please order separately. Threads are G 1/4. Thermally conductive paste is required for installation.
Materials:
Terminal: Delrin
Scope of delivery:
Please note:
This Product was added to our catalogue on 28/10/2014.
Manufacturer Information
Contact Manufacturer
Aqua Computer GmbH & Co. KG Gelliehäuser Str. 1
37130 Gleichen
Germany
info@aqua-computer.de
Anschlüsse
A product slider follows - navigate to the individual items using the Tab key.
Coupling 10/8 mm G 1/4 with O-gasket
Coupling 10/8 mm G 1/4 m. O-gasket elbow, pivotable
Coupling 8/6 mm G 1/4 with O-gasket
Coupling 8/6 mm G 1/4 w. O-gasket elbow, pivotable
Coupling 11/8 mm G 1/4, straight
Coupling 11/8 mm G 1/4 elbow, pivotable
Coupling 13/10 mm G 1/4 with O-gasket
Coupling 13/10 mm G 1/4 m. O-gasket elbow, pivotable
Straight plug&cool fitting G 1/4
Elbow fitting plug&cool G 1/4, pivotable
Zubehör
kryoconnect kit for kryographics, width 4 slots for 2 graphics cards
kryoconnect kit for kryographics, width 5 slots for 2 or 3 graphics cards
kryoconnect kit for kryographics, width 7 slots for max. 7 graphics cards
VISION Glow connection terminal for kryographics
This product is compatible with:
Back plate for kryographics GTX 980, passive
Back plate for kryographics GTX 980, active XCS
Customers who bought this product also bought the following products:
Double Protect Ultra 1l - blue
Thermal Grizzly Kryonaut thermal compound - 11.1 grams / 3 ml
kryoM.2 micro passive heat sink for M.2 2280 SSD
Last viewed:
kryographics for GTX 980 black edition, nickel plated version
Feedthrough coupling with cap nuts 11/8 mm
fangrill 80 mm chromed
Pressure equalisation membrane G1/4, tall version
