Decoupling rubber for 120 mm-fan
Product no.: 51114
If there is more than one product image, you can use the "Previous" and "Next" buttons to navigate between the images. For a larger view click on the image.
For a larger view click on the image!
1,99 EUR
incl. 19 % VAT excl. shipping costs
Products description
Diese weichen Lüfterentkopplungsgummis aus Silikon werden zwischen Lüfter und Gehäusewand montiert und sorgen auf der gesamten Anlagefläche für eine wirksame Dämpfung der Vibrationsübertragung.
Passend für Lüfter mit Abmessungen von 120 x 120 mm.
Lieferumfang:
1 Stück Entkopplungsgummi
This Product was added to our catalogue on 05/12/2008.
Manufacturer Information
Contact Manufacturer
Aqua Computer GmbH & Co. KG
Gelliehäuser Str. 1
37130 Gleichen
Germany
info@aqua-computer.de
Customers who bought this product also bought the following products:
A product slider follows - navigate to the individual items using the Tab key.
Mounting plate for airplex modularity system 240 and radical/PRO/XT 240, brushed stainless steel
Temperature sensor internal/external thread G1/4
USB cable A-plug to 5 pin female connector, length 200 cm
QUADRO fan controller for PWM fans
Temperature sensor inline G1/4
Connection cable signal header miniature connector (high flow NEXT, OCTO) to fan header
Last viewed:
Settings
Shipping country
Languages
Your account
Categories
