Products description
The 4-pin Y-splitter/converter is suitable for connecting two 4-pin fans to a 4-pin fan output. Please note that the rotational speed signal can only be monitored for one connected fan.
Specifications:
4-pin female to 2x 4-pin male connectors
Total length including connectors approx. 10 cm
Scope of delivery:
One Y-splitter/converter
Specifications:
Scope of delivery:
This Product was added to our catalogue on 21/02/2018.
Manufacturer Information
Contact Manufacturer
Aqua Computer GmbH & Co. KG Gelliehäuser Str. 1
37130 Gleichen
Germany
info@aqua-computer.de
Customers who bought this product also bought the following products:
A product slider follows - navigate to the individual items using the Tab key.
Tubing PUR natur, plug&cool
Hose cutter for a maximum diameter of 16 mm
Elbow fitting plug&cool G 1/4, pivotable
kryographics NEXT RTX 2080 Ti / Titan RTX nickel plated version
Back plate for kryographics NEXT RTX 2080 Ti / Titan RTX, passive
Temperature sensor G1/4
Last viewed:
Y-splitter for 4-pin fans
Plug for power output connector (aquaero 5 and 6) or relay connector (aquaero 4), 2 contacts
