Products description
Notice for international shoppers: Due to its light weight and compact size, we can offer attractive shipping costs of EUR 5.00 for this product to any destination outside the European Union, EUR 5.95 including VAT for any destination within the EU. Please select shipping option "Padded envelope" during checkout for economy shipping.
The kryoM.2 micro is a passive heat sink for single sided M.2 SSDs and is compatible with the form factor 2280.
Special features of the kryoM.2 micro:
- High-quality heat sink made from aluminum, black anodized with laser engraving
- Stainless steel clips for easy installation
- High performance thermal pad included in delivery
- Self-adhesive protective foil for electrical insulation of the stainless steel clips included in delivery
The kryoM.2 micro can easily be attached to the SSD using the stainless steel clips. The thermal pad included in delivery is installed between SSD and heat sink for optimum heat transfer. The cooling performance of the passive heat sink is sufficient for most applications. Due to the compact design, the heat sink can be used with nearly all motherboard brands and models.
During installation, the SSD does not suffer mechanical stress. The clips are slid on from the sides and then clamped onto the edge of the heat sink, the clamp does not touch the edge of the SSD board.
Dimensions ca. 70 x 24 x 9 mm including clips
Scope of delivery:
Passive heat sink made from aluminum, black anodized
Two clips made from stainless steel
Thermal pad
Protective foil for rear side of the SSD
Please note: SSD not included in delivery. Compatible with M.2 form factor 2280 (width 22 mm, length 80 mm), heights S1/S2/S3 (single sided, maximum component height 1.2/1.35/1.5 mm, corresponding to max. 2.3 mm including PCB).
Scope of delivery:
Thermal pad
This Product was added to our catalogue on 31/03/2017.
Manufacturer Information
Contact Manufacturer
Aqua Computer GmbH & Co. KG Gelliehäuser Str. 1
37130 Gleichen
Germany
info@aqua-computer.de
Customers who bought this product also bought the following products:
A product slider follows - navigate to the individual items using the Tab key.
Plug for power output connector (aquaero 5 and 6) or relay connector (aquaero 4), 2 contacts
RGBpx cable, length 50 cm
RGBpx adapter for components with motherboard header
RGBpx extension cable, length 50 cm
Mounting bracket 120 mm fan mount for ULTITUBE D5 reservoir
Fixation ring for ULTITUBE reservoirs
Last viewed:
kryoM.2 micro passive heat sink for M.2 2280 SSD
Washer for M3, A2
