Products description
VISION RGBpx module assembly to be used as a replacement part for VISION RGBpx connection terminal for kryographics (23688, 23689).
Notes on the aquasuite software:
When you activate this product you will receive the current version of the aquasuite software including an upgrade service for at least six (6) months. After the expiration of the upgrade service you may use and reinstall the latest version available during the upgrade period without a time limit.
The update service can optionally be extended or renewed at any time for a fee.
Please note that an internet connection is required for the installation and activation of the aquasuite software.
Further information about the update service and the activation of the aquasuite software can be found here.
This Product was added to our catalogue on 06/08/2021.
Manufacturer Information
Contact Manufacturer
Aqua Computer GmbH & Co. KG Gelliehäuser Str. 1
37130 Gleichen
Germany
info@aqua-computer.de
Customers who bought this product also bought the following products:
A product slider follows - navigate to the individual items using the Tab key.
USB cable A-plug to 5 pin miniature connector, length 200 cm
QUADRO fan controller for PWM fans
D5 NEXT pump
internal USB connection cable 100 cm with miniature connector
RGBpx LED strip 27.3 cm, width 5 mm, 30 addressable LEDs
RGBpx adapter for components with motherboard header
Last viewed:
VISION RGBpx replacement module for kryographics connection terminal
