Products description
The QUADRO made by Aqua Computer is a four channel PWM fan controller with outstanding functionality, equally suited for water cooled or air cooled computers. Additionally, it features an RGBpx effect controller for 90 addressable LEDs.
Key features of the QUADRO include:
· Programmable four channel fan controller
· All fan outputs supply up to 25 Watt of power per channel and include speed monitoring
· All fan outputs with 4-Pin connector and PWM controlled
· All fan outputs can be switched off completely
· Versatile control options
· Four temperature sensor inputs
· Eight further values can be transferred from the PC to the QUADRO using the aquasuite software
· Flow sensor input
· RGBpx LED output for LED strips and fans with individually controllable LEDs
· USB 2.0 interface
· aquasuite software for a comfortable setup, evaluation and visualization of all sensor data
· aquabus interface: When connected to an aquaero, the fan outputs can be controlled by the aquaero
QUADRO Teaser Video
Fan controller
The four fan channels of the QUADRO can be configured independently, the high maximum power output of 25 watts per channel allows for connecting multiple fans to each output of the QUADRO using suitable splitters. In addition to setting fan speed manually, fan speed can also be controlled by temperature. In temperature controlled mode, set point controllers as well as curve controllers are available. If the corresponding temperature falls below the set limit, connected fans can either be switched off or be kept running at an adjustable minimum speed. For secure fan start-up, an intelligent start boost with speed signal monitoring can be configured for each fan channel.
All fan outputs are compatible to PWM fans with four pin connectors only and feature overload protection.
RGBpx controller for addressable LEDs
The QUADRO controller is equipped with an RGBpx output for controlling up to 90 addressable LEDs independently. Color and brightness can be individually controlled for each LED. In total, up to four groups of LEDs of varying size can be configured, and visual effects can be assigned to each group. The 23 available effects can be extensively adjusted for further customization. Many effects can also be configured to modify effect parameters (for example speed) depending on current sensor data. The available effects also include sound-to-light effects, visualizing computer sound output. The AMBIENTpx effect deserves special notice, replicating the border area of the current monitor display on connected LEDs, allowing for an impressive background lighting surrounding the monitor.
Alternatively to the LED strips offered by Aqua Computer, LED fans made by Corsair and NZXT can be connected using the optional accessory RGBpx Splitty4 (item code 53267, not included in delivery).
RGBpx Demo Video
QUADRO can be used as an aquabus expansion device
Besides being a fully autonomous USB fan controller, the QUADRO can also be used as an aquabus extension to an aquaero 5 or aquaero 6. In this configuration, the four fan channels of the QUADRO can be controlled by the aquaero, temperature sensor inputs and flow sensor input are transmitted to the aquaero. A maximum of two QUADRO controllers can be connected to an aquaero simultaneously.
Technical details
Dimensions without attached cables: ca. 54 x 49 x 17 mm
Supply voltage: 5V, 12V
Maximum fan output power: 25 watts per channel
PWM control signal: 0 - 100 %, resolution 0,1 %
Scope of delivery
- QUADRO controller
- one temperature sensor, length approx. 70 cm
- one internal USB cable, length approx. 100 cm
- mounting material
System requirements
- Windows 10 or newer
- Internal USB 2.0 port
Notes on the AMBIENTpx effect
Screen content preventing analysis by DRM or similar methods cannot be utilized for the effect.
Notes on the aquasuite software:
When you activate this product you will receive the current version of the aquasuite software including an upgrade service for at least six (6) months. After the expiration of the upgrade service you may use and reinstall the latest version available during the upgrade period without a time limit.
The update service can optionally be extended or renewed at any time for a fee.
Please note that an internet connection is required for the installation and activation of the aquasuite software.
Further information about the update service and the activation of the aquasuite software can be found here.
· Flow sensor input
· USB 2.0 interface
QUADRO Teaser Video
Fan controller
RGBpx Demo Video
Technical details
Scope of delivery
- QUADRO controller
- mounting material
System requirements
This Product was added to our catalogue on 29/06/2018.
Manufacturer Information
Contact Manufacturer
Aqua Computer GmbH & Co. KG Gelliehäuser Str. 1
37130 Gleichen
Germany
info@aqua-computer.de
Anschlusskabel
A product slider follows - navigate to the individual items using the Tab key.
SPLITTY9 splitter for up to 9 fans or aquabus devices
Connection cable flow sensor for VISION, OCTO, QUADRO, farbwerk 360
aquabus cable 4 pins for VISION, OCTO, QUADRO, D5 NEXT
RGBpx
RGBpx Splitty4
RGBpx lighting set for PC case, 60 addressable LEDs
RGBpx lighting set for monitors, 60 addressable LEDs
RGBpx LED ring for aqualis 450/880, 15 addressable LEDs
RGBpx LED ring for aqualis 100/150, 10 addressable LEDs
RGBpx LED ring for 60 mm reservoir, 12 addressable LEDs
Sensor
Temperature sensor plug&cool
Temperature sensor 70 cm
Temperature sensor inline G1/4
Temperature sensor internal/external thread G1/4
Temperature sensor G1/4
Flow sensor high flow LT, G1/4
Flow sensor high flow 2, G1/4
Temperature sensor 15 cm
This product is compatible with:
RGBpx cable, length 4 cm
RGBpx cable, length 10 cm
RGBpx cable, length 50 cm
RGBpx cable, length 200 cm
RGBpx Splitty4
RGBpx LED strip 32 cm, width 10 mm, 15 addressable LEDs
RGBpx LED strip 27.3 cm, width 5 mm, 15 addressable LEDs
RGBpx LED strip 27.3 cm, width 5 mm, 30 addressable LEDs
RGBpx adapter for components with motherboard header
RGBpx LED ring for ULTITUBE reservoirs, 13 addressable LEDs
RGBpx bracket for two RGBpx connections
RGBpx cable, length 20 cm
Arctic F12 PWM PST, black (ACFAN00200A)
be quiet! Silent Wings 4 120 mm PWM
be quiet! Silent Wings 4 120 mm PWM high-speed
be quiet! Silent Wings 4 140 mm PWM
be quiet! Silent Wings 4 140 mm PWM high-speed
be quiet! Silent Wings Pro 4 120 mm PWM
be quiet! Silent Wings Pro 4 140 mm PWM
be quiet! Pure Wings 3 120 mm PWM
be quiet! Pure Wings 3 120 mm PWM high speed
be quiet! Pure Wings 3 140 mm PWM
be quiet! Pure Wings 3 140 mm PWM high speed
Customers who bought this product also bought the following products:
Hose barb 6 mm G 1/4 with O-ring-gasket
USB cable A-plug to 5 pin miniature connector, length 200 cm
Barrow T-connector, internal thread G1/4, silver
Last viewed:
QUADRO fan controller for PWM fans
Retrofit kit socket AM5/AM4 for cuplex EVO
airplex modularity system 280 mm, copper fins, D5 NEXT pump, stainless steel side panels
cuplex kryos NEXT VARIO with VISION AM5/AM4 9000/8000/7000/5000/3000, nickel/.925 silver
cuplex kryos NEXT VARIO 2011/2011-3/2066, nickel/.925 silver
cuplex kryos NEXT 2011/2011-3/2066, copper/.925 silver
