internal USB connection cable 100 cm with miniature connector
Product no.: 53215
GTIN/EAN: 4260073419222
MPN: 53215
If there is more than one product image, you can use the "Previous" and "Next" buttons to navigate between the images. For a larger view click on the image.
For a larger view click on the image!
3,90 EUR
incl. 19 % VAT excl. shipping costs
Products description
Internal USB connection cable to connect an Aqua Computer USB device with miniature connector to a free USB port (pin header) of the mainboard. Length approx. 100 cm.
Scope of delivery:
One cable
Compatible devices:
cuplex kryos NEXT with VISION
VISION connection terminal for kryographics (23664, 23665, 23666, 23667)
VISION RGBpx connection terminal for kryographics (23686, 23687)
D5 NEXT (41118)
VISION Touch (53232, 53235)
QUADRO (53256)
farbwerk 360 (53279)
farbwerk nano (53280, 53281)
OCTO (53286)
high flow NEXT (53293)
LEAKSHIELD (34137, 34138, 34144, 34146)
This Product was added to our catalogue on 18/11/2016.
Manufacturer Information
Contact Manufacturer
Aqua Computer GmbH & Co. KG
Gelliehäuser Str. 1
37130 Gleichen
Germany
info@aqua-computer.de
Customers who bought this product also bought the following products:
A product slider follows - navigate to the individual items using the Tab key.
Hose ClearFlex60 12,7/9,5 mm clear
Double Protect Ultra 5l canister
Double Protect Ultra 5l canister - blue
Temperature sensor 70 cm (miniature connector)
Temperature sensor 5 cm (miniature connector)
SPLITTY9 ACTIVE - active splitter for up to 9 PWM fans
Last viewed:
Settings
Shipping country
Languages
Your account
Categories
