Products description
CPU water block for sTRX4 and sTR5/SP6, perfectly adapted to the revised chip layout of the third generation of Threadripper CPUs.
Base part with micro structure
All components of the water block are CNC machined at Aqua Computer's headquarters in Germany. The copper base features a huge area microstructure (51 x 45 mm), which is machined with the finest spacing manufactured by Aqua Computer (less than 0.2 mm). This microstructure is one of the reasons for the exceptional cooling performance of the cuplex kryos NEXT sTRX4 FC.
The contact area to the CPU is machined with increased precision and then polished for perfect heat transfer. Additionally, the copper base is finished with nickel plating.
Full size CPU coverage
The "FC" token stands for "Full Cover" - the copper base of the water black covers the whole CPU. Heat generation is not distributed evenly within the CPU, thermal energy is concentrated in certain areas. Specially designed for the third processor generation, an optimized internal coolant flow ensures maximum cooling performance in the areas where thermal energy is generated.
Retention system
The cuplex kryos NEXT sTRX4 FC retention system ensures easy installation. Recessed springs and screws with mechanical stop
result in optimum clamping force and even force distribution.
For optimum performance, outstanding thermal compound is included. A syringe with 1 gram of Thermal Grizzly Kryonaut is included, complete with plastic spatula. This compound has a high thermal conductivity and spreads out thin and evenly between CPU and water block due to its low viscosity.
Material combination
Base material: Copper, nickel plated
Housing material: Acetal, black
Technical details
Dimensions: ca. 117 x 77 x 16 mm (not including screws)
Connection threads: G1/4
Distance between threads: 69 mm
Compatible processor sockets: sTR5, SP6, sTRX4, sWRX8, TR4, SP3
Scope of delivery
- Water block
- Mounting material (screws, springs)
- Thermal compound Thermal Grizzly Kryonaut, approx. 1 grams in syringe
- Plastic spatula
- Instruction manual
Retention system
Technical details
Scope of delivery
- Water block
- Plastic spatula
This Product was added to our catalogue on 12/06/2020.
Manufacturer Information
Contact Manufacturer
Aqua Computer GmbH & Co. KG Gelliehäuser Str. 1
37130 Gleichen
Germany
info@aqua-computer.de
Anschlüsse
A product slider follows - navigate to the individual items using the Tab key.
Coupling 10/8 mm G 1/4 with O-gasket
Coupling 8/6 mm G 1/4 with O-gasket
Coupling 11/8 mm G 1/4, straight
Coupling 13/10 mm G 1/4 with O-gasket
Straight plug&cool fitting G 1/4
Customers who bought this product also bought the following products:
Feedthrough plug&cool metal
Locking cap plug&cool plastic
Straight plug&cool fitting G 1/8
Straight plug&cool fitting G 1/8 internal thread
Gasket 11.11 x 1.78 mm for connectors G1/4
aquatube G1/4 Delrin black
Last viewed:
cuplex kryos NEXT sTRX4 FC, acetal (compatible with sTR5/SP6)
Feedthrough coupling with cap nuts 8/6 mm
airplex modularity system 140 mm, aluminum fins, two circuits, stainless steel side panels
Fan rails (one pair) for airplex GIGANT 3360
cuplex kryos NEXT RGBpx AM5/AM4 9000/8000/7000/5000/3000, acetal/.925 silver
cuplex kryos NEXT RGBpx AM5/AM4 9000/8000/7000/5000/3000, acrylic/.925 silver
