Products description
Combined GPU/RAM/VRM-cooler for graphics cards of the type nvidia GeForce GTX 680 with 2048 MB RAM according to reference design.
This cooler combines the features of a graphics chip cooler and RAM-coolers in an elegant and very flat watercooler. Additionally the voltage regulators are also cooled effectively.
The kryographics for GTX 680 water block offers outstanding cooling performance and a low flow resistance. All mounting threads are equipped with spacers for easy installation and to prevent twisting the graphics card. The areas contacting the GPU and RAM modules are polished for excellent heat transfer. For the voltage regulators, a thermal pad with high thermal conductivity is included.
The kryoconnect water block series features a delrin connection terminal that has a significantly reduced flow resistance compared to the previous aquagraFX series. The terminal is fastened to the water block by three screws and has G1/4 inlet and outlet ports on each side for flexible installation. Two sealing screws are supplied to seal the unused connection threads. The terminal can be replaced with kryoconnect kits for SLI configurations (art. no. 23551, 23552 or 23553, not included in delivery).
Materials:
Base part: Copper
Top cover: Stainless steel
Terminal: Delrin
Scope of delivery:
cooler without connectors (screw threads G 1/4)
mounting material incl. thermally conductive pad
two sealing plugs for unused connection threads
Torx screwdriver (for removal of the air cooling unit)
Please note:
Graphic card and fittings are not included in delivery, please order separately. Threads are G 1/4.
Installation-Video:
Materials:
Base part: Copper
Terminal: Delrin
Scope of delivery:
Please note:
Installation-Video:
This Product was added to our catalogue on 25/02/2015.
Manufacturer Information
Contact Manufacturer
Aqua Computer GmbH & Co. KG Gelliehäuser Str. 1
37130 Gleichen
Germany
info@aqua-computer.de
Anschlüsse
A product slider follows - navigate to the individual items using the Tab key.
Coupling 10/8 mm G 1/4 with O-gasket
Coupling 10/8 mm G 1/4 m. O-gasket elbow, pivotable
Coupling 8/6 mm G 1/4 with O-gasket
Coupling 8/6 mm G 1/4 w. O-gasket elbow, pivotable
Coupling 11/8 mm G 1/4, straight
Coupling 11/8 mm G 1/4 elbow, pivotable
Coupling 13/10 mm G 1/4 with O-gasket
Coupling 13/10 mm G 1/4 m. O-gasket elbow, pivotable
Straight plug&cool fitting G 1/4
Elbow fitting plug&cool G 1/4, pivotable
Zubehör
kryoconnect kit for kryographics, width 4 slots for 2 graphics cards
kryoconnect kit for kryographics, width 5 slots for 2 or 3 graphics cards
kryoconnect kit for kryographics, width 7 slots for max. 7 graphics cards
Customers who bought this product also bought the following products:
aquaero power connect - 24 pin ATX standby power / ATX break
Temperature sensor inline G1/4
HUBBY7 internal USB 2.0 Hub
farbwerk 360
Last viewed:
