Decoupling rubber for 140 mm-fan
Product no.: 51146
GTIN/EAN: 5999094003460
If there is more than one product image, you can use the "Previous" and "Next" buttons to navigate between the images. For a larger view click on the image.
For a larger view click on the image!
4,90 EUR
incl. 19 % VAT excl. shipping costs
Products description
Diese weichen Lüfterentkopplungsgummis aus Silikon werden zwischen Lüfter und Gehäusewand montiert und sorgen auf der gesamten Anlagefläche für eine wirksame Dämpfung der Vibrationsübertragung.
Passend für Lüfter mit Abmessungen von 140 x 140 mm.
Lieferumfang:
1 Stück Entkopplungsgummi
This Product was added to our catalogue on 19/06/2013.
Manufacturer Information
Contact Manufacturer
Aqua Computer GmbH & Co. KG
Gelliehäuser Str. 1
37130 Gleichen
Germany
info@aqua-computer.de
Customers who bought this product also bought the following products:
A product slider follows - navigate to the individual items using the Tab key.
Double Protect Ultra 5l canister
Aqua Computer D5 pump motor with PWM input and speed signal
RGBpx cable, length 10 cm
farbwerk 360
farbwerk 360
OCTO fan controller for PWM fans
D5 NEXT pump
D5 NEXT pump
Last viewed:
Connection cable for flow sensor, length 70 cm for aquaero/aquastream/poweradjust/D5 NEXT
Settings
Shipping country
Languages
Your account
Categories
