Products description
This cable can be used to connect an Aqua Computer USB device with a miniature USB header to an A-receptacle of the computer. Length approx. 200 cm.
Scope of delivery:
One cable
Compatible devices:
cuplex kryos NEXT with VISION
VISION connection terminal for kryographics (23664, 23665, 23666, 23667)
VISION RGBpx connection terminal for kryographics (23686, 23687)
D5 NEXT (41118)
VISION Touch (53232, 53235)
QUADRO (53256)
farbwerk 360 (53279)
farbwerk nano (53280, 53281)
OCTO (53286)
high flow NEXT (53293)
LEAKSHIELD (34137, 34138, 34144, 34146)
Scope of delivery:
One cable
Compatible devices:
D5 NEXT (41118)
QUADRO (53256)
OCTO (53286)
This Product was added to our catalogue on 18/11/2016.
Manufacturer Information
Contact Manufacturer
Aqua Computer GmbH & Co. KG Gelliehäuser Str. 1
37130 Gleichen
Germany
info@aqua-computer.de
This product is compatible with:
A product slider follows - navigate to the individual items using the Tab key.
Adapter for PET bottles for LEAKSHIELD
Customers who bought this product also bought the following products:
RGB Splitty3 incl. LED
RGBpx adapter for components with motherboard header
Mounting bracket 120 mm fan mount for ULTITUBE D5 reservoir
Mounting bracket 140 mm fan mount for ULTITUBE D5 reservoir
Standalone mounting kit for LEAKSHIELD
Power supply 4-Pin Y-Splitter
Last viewed:
USB cable A-plug to 5 pin miniature connector, length 200 cm
