Products description
The cuplex kryos NEXT marks a new milestone in CPU water block development. Every detail has been analyzed, optimized and tested to achieve perfection in cooling performance, installation procedure and product features. The result is not just a CPU water block with outstanding performance - it is a product series with various models differing in color and functionality. The VARIO models are the first CPU water blocks globally to incorporate a real-time adjustable base - never before has it been possible to adjust the geometry of a CPU block to perfectly fit the CPU while the PC is in operation. Models with VISION module are equipped with modern electronics: High resolution OLED display, integrated water temperature sensor and USB interface are just three of the features.
Base part with micro structure
The base part of the cuplex kryos NEXT is equipped with an extremely fine micro structure, the structural width is lower than 200 µm. The coolant is injected centrally through a slot-shaped nozzle and then runs to both sides of the structure. The base itself is manufactured from copper, nickel plated copper or .925 sterling silver depending on model.
Retention system
The cuplex kryos NEXT retention system consists of 2.5 mm thick stainless steel plates equipped with nickel plated spring cups. Springs and knurled screws secure the water block on the motherboard, the retention system has a very clean look when installed. All retention system versions feature a mechanical stop for optimum clamping force and even force distribution. The knurled screws can be installed by hand, additionally a hexagon socket wrench can be used for easy installation.
All water block versions for socket 1851/1700 include a steel back plate with rubber insulation to stabilize the CPU region of the motherboard.
For optimum performance, every cuplex kryos NEXT ships with outstanding thermal compound. A syringe with 0.5 grams of premium grade thermal compound is included, complete with plastic spatula. This compound has a high thermal conductivity and spreads out thin and evenly between CPU and water block due to its low viscosity. The amount is sufficient for approximately five applications.
VARIO: Adjustable geometry
The geometry of the base part of cuplex kryos NEXT VARIO variants can be adjusted using four adjusting screws on the sides of the water block. Each CPU is unique - even slightest variations in height or shape of the metallic lids on top of current CPUs affect cooling performance of a water block considerably. Prior concepts to adjust the geometry of water blocks always required the water block to be disassembled and then reinstalled onto the motherboard, requiring significant time and effort. With the cuplex kryos NEXT VARIO, the geometry is perfectly adjusted in just a few moments. While monitoring core temperatures at maximum CPU load, simply change the geometry using the four adjusting screws. Temperature changes provide an immediate feedback, the perfect setting is quickly identified.
VISION: Integrated electronics
The VISION variants of the cuplex kryos NEXT are equipped with a microcontroller board and OLED display. The features include:
- Water temperature sensor integrated in water block
- Connector for flow sensor, can alternatively be used as alarm output
- USB interface
- aquabus interface for communication with an aquaero 5 or 6
- Customizable display output
- Various hardware data can be displayed from the aquasuite software, for example current CPU load
The acrylic glass variants of the cuplex kryos NEXT with VISION are additionally equipped with a RGB LED that can be controlled depending on temperature or via USB.
Due to limited space, a maximum of two cables can be threaded into the water block. The following combinations are possible:
- USB and aquabus
- USB and flow sensor or alarm output
- aquabus and flow sensor or alarm output
Color variants
The top part of the water block is available in various materials and coatings:
Acetal black: Shiny black high-tech plastic
Acrylic glass: Transparent body suitable for illumination
Copper: Reddish gloss
Nickel plated brass: Bright metallic gloss
PVD plated brass: High quality multi layer coating, dark metallic gloss
Material combination
Copper/.925 silver: Top part copper, base 925/000 sterling silver
Technical details
Dimensions:
Socket 1700: 94 x 94 x 22 mm (not including screws and back plate)
Connection threads: G1/4
Distance between threads: 24 mm
Scope of delivery
- Water block
- Internal USB connection cable, length approx. 100 cm (pre-installed)
- Back plate
- Mounting material (screws, springs, etc.)
- Premium thermal compound, approx. 0.5 grams in syringe
- Plastic spatula
- Instruction manual
Video presentation:
Reviews:
TechPowerUp
ComputerBase
Cooling Technique
Thermalbench
Overclockers.com
Review Studio
Hardwareoverclock.com
Notes on the aquasuite software:
When you activate this product you will receive the current version of the aquasuite software including an upgrade service for at least six (6) months. After the expiration of the upgrade service you may use and reinstall the latest version available during the upgrade period without a time limit.
The update service can optionally be extended or renewed at any time for a fee.
Please note that an internet connection is required for the installation and activation of the aquasuite software.
Further information about the update service and the activation of the aquasuite software can be found here.
Retention system
- USB interface
- USB and aquabus
Color variants
Technical details
Dimensions:
Scope of delivery
- Water block
- Back plate
- Plastic spatula
Video presentation:
Reviews:
TechPowerUp
ComputerBase
Cooling Technique
Thermalbench
Overclockers.com
Review Studio
This Product was added to our catalogue on 23/11/2021.
Manufacturer Information
Contact Manufacturer
Aqua Computer GmbH & Co. KG Gelliehäuser Str. 1
37130 Gleichen
Germany
info@aqua-computer.de
Anschlüsse
A product slider follows - navigate to the individual items using the Tab key.
Coupling 10/8 mm G 1/4 with O-gasket
Coupling 8/6 mm G 1/4 with O-gasket
Coupling 11/8 mm G 1/4, straight
Coupling 13/10 mm G 1/4 with O-gasket
Straight plug&cool fitting G 1/4
Backplate
Reinforced back plate for socket 1851/1700
Customers who bought this product also bought the following products:
Coupling 13/10 mm G 1/4 m. O-gasket elbow, pivotable
Coupling 13/10 mm G 1/4 m. O-gasket 45° elbow, pivotable
Filter with stainless steel mesh, ball valves and mounting plate, G1/4
Double Protect Ultra 1l - blue
Bezel for filter with stainless steel mesh, 120 mm fan mounting
airplex modularity system 420 mm, copper fins, one circuit, stainless steel side panels
Last viewed:
cuplex kryos NEXT with VISION 1851/1700, copper/.925 silver
airplex modularity system 480 mm, copper fins, two circuits, stainless steel side panels
airplex modularity system 240 mm, copper fins, D5 NEXT pump, stainless steel side panels
cuplex kryos NEXT VARIO with VISION 1851/1700, nickel/.925 silver
Barrow compression fitting 16/10 mm G1/4, black
cuplex kryos NEXT with VISION 1851/1700, copper/copper
