Products description
The cuplex kryos NEXT marks a new milestone in CPU water block development. Every detail has been analyzed, optimized and tested to achieve perfection in cooling performance, installation procedure and product features. The result is not just a CPU water block with outstanding performance - it is a product series with various models differing in color and functionality.
Base part with micro structure
The base part of the cuplex kryos NEXT is equipped with an extremely fine micro structure, the structural width is lower than 200 µm. The coolant is injected centrally through a slot-shaped nozzle and then runs to both sides of the structure. The base itself is manufactured from copper, nickel plated copper or .925 sterling silver depending on model.
Retention system
The cuplex kryos NEXT retention system consists of 2.5 mm thick stainless steel plates equipped with nickel plated spring cups. Springs and knurled screws secure the water block on the motherboard, the retention system has a very clean look when installed. All retention system versions feature a mechanical stop for optimum clamping force and even force distribution. The knurled screws can be installed by hand, additionally a hexagon socket wrench can be used for easy installation.
Water blocks for socket 115x or AM3 include a steel back plate with silicone insulation to stabilize the CPU region of the motherboard. Socket 2011, 2066, AM5/AM4 und TR4 motherboards already include a back plate as part of the CPU socket, therefore no additional back plate is required.
When using the AM5/AM4 9000/8000/7000/5000/3000 retention system, the water block is not centered on the CPU. Instead, the water block is installed slightly off-center for optimum heat dissipation in accordance with the asymmetrical internal design of these CPU series.
For optimum performance, every cuplex kryos NEXT ships with outstanding thermal compound. A syringe with 0.5 grams of premium grade thermal compound is included, complete with plastic spatula. This compound has a high thermal conductivity and spreads out thin and evenly between CPU and water block due to its low viscosity. The amount is sufficient for approximately five applications.
Integrated RGBpx LEDs
Below the black colored aluminum frame, 11 addressable RGBpx LEDs are integrated into the water block and can be connected to an Aqua Computer device with a RGBpx output.
Material combination
Acrylic/.925 silver: Top part acrylic glass with anodized aluminum frame, base 925/000 sterling silver
Technical details
Dimensions:
Socket AM5/AM4: 111 x 75 x 22 mm (not including screws)
Connection threads: G1/4
Distance between threads: 25.5 mm
Scope of delivery
- Water block
- Mounting material (screws, springs, etc.)
- Premium thermal compound, approx. 0.5 grams in syringe
- Plastic spatula
- RGBpx connection cable 50 cm
- Instruction manual
Video presentation:
Reviews:
TechPowerUp
ComputerBase
Cooling Technique
Thermalbench
Overclockers.com
Review Studio
Hardwareoverclock.com
Retention system
Technical details
Dimensions:
Scope of delivery
- Water block
- Plastic spatula
Video presentation:
Reviews:
TechPowerUp
ComputerBase
Cooling Technique
Thermalbench
Overclockers.com
Review Studio
This Product was added to our catalogue on 31/08/2020.
Manufacturer Information
Contact Manufacturer
Aqua Computer GmbH & Co. KG Gelliehäuser Str. 1
37130 Gleichen
Germany
info@aqua-computer.de
Anschlüsse
A product slider follows - navigate to the individual items using the Tab key.
Coupling 10/8 mm G 1/4 with O-gasket
Coupling 8/6 mm G 1/4 with O-gasket
Coupling 11/8 mm G 1/4, straight
Coupling 13/10 mm G 1/4 with O-gasket
Straight plug&cool fitting G 1/4
Backplate
Reinforced back plate for socket AM5
RGBpx
farbwerk 360
farbwerk nano (internal)
RGBpx adapter for connecting RGBpx components to motherboard headers
Customers who bought this product also bought the following products:
cuplex kryos NEXT AM5/AM4 9000/8000/7000/5000/3000, acetal/nickel
cuplex kryos NEXT with VISION AM5/AM4 9000/8000/7000/5000/3000, nickel/nickel
cuplex kryos NEXT with VISION AM5/AM4 9000/8000/7000/5000/3000, PVD/nickel
cuplex kryos NEXT VARIO with VISION AM5/AM4 9000/8000/7000/5000/3000, nickel/nickel
cuplex kryos NEXT RGBpx AM5/AM4 9000/8000/7000/5000/3000, acrylic/nickel
cuplex kryos NEXT RGBpx AM5/AM4 9000/8000/7000/5000/3000, acrylic/.925 silver
Last viewed:
cuplex kryos NEXT RGBpx black AM5/AM4 9000/8000/7000/5000/3000, acrylic/.925 silver
Screw M3 x 8 mm, low head socket cap, hexagon socket, black
cuplex kryos NEXT AM5/AM4, PVD/.925 silver
Retrofit kit socket AM5/AM4 for cuplex kryos NEXT RGBpx
cuplex kryos NEXT with VISION AM5/AM4 9000/8000/7000/5000/3000, nickel/.925 silver
