Products description
Dr. Drop is an ingeniously simple pressure tester for your entire water cooling loop or for single components.
With an included air pump, a test pressure can be applied. A large manometer with a diameter of 63 mm allows for precise pressure readings. A second valve is included to adjust pressure for easy testing over prolonged periods of time and to discharge the pressure after testing.
The pressure tester has a G1/4 inner thread to be equipped with a hose fitting compatible to your preferred hose diameter.
Added bonus for bicyclists: The air pump fits car tire valves (Schrader) as well as French (Sclaverand) tyre valves. A pump holder (hole pattern like bottle holder) is included as well.
Technical details:
Base part material: Delrin, black
Measuring range: 0 - 0.6 bar (approx. 0 - 8.7 PSI)
Connection thread: G1/4
Scope of delivery:
Pressure tester
Air pump
Hose fitting and hose not included in delivery!
Technical details:
Scope of delivery:
Pressure tester
Air pump
This Product was added to our catalogue on 10/06/2016.
Manufacturer Information
Contact Manufacturer
Aqua Computer GmbH & Co. KG Gelliehäuser Str. 1
37130 Gleichen
Germany
info@aqua-computer.de
Anschlüsse
A product slider follows - navigate to the individual items using the Tab key.
Coupling 10/8 mm G 1/4 with O-gasket
Coupling 10/8 mm G 1/4 m. O-gasket elbow, pivotable
Coupling 8/6 mm G 1/4 with O-gasket
Coupling 8/6 mm G 1/4 w. O-gasket elbow, pivotable
Coupling 11/8 mm G 1/4, straight
Coupling 11/8 mm G 1/4 elbow, pivotable
Coupling 13/10 mm G 1/4 with O-gasket
Coupling 13/10 mm G 1/4 m. O-gasket elbow, pivotable
Straight plug&cool fitting G 1/4
Elbow fitting plug&cool G 1/4, pivotable
Customers who bought this product also bought the following products:
Double Protect Ultra 5l canister
RGBpx adapter for components with motherboard header
RGBpx cable, length 20 cm
OCTO fan controller for PWM fans
Double Protect Ultra 1l
Double Protect Ultra 1l - blue
Last viewed:
Dr. Drop pressure tester incl. air pump
cuplex kryos NEXT VARIO with VISION 2011/2011-3/2066, nickel/nickel
